Romany Sportive
Our two plastic models are roto-moulded, creating a robust single-layer construction with a wall thickness of approximately 5mm. This durable material can withstand extensive use, making it ideal for centre use, rock hopping, and heavy landings. Even in the event of damage, the plastic material is easy to repair. These plastic models offer a cost-effective option, perfect for centres, beginners, or as a secondary boat for adventurous rock hopping. Available in five attractive colours, the plastic models can be further customized with composite seats and cockpit rims, allowing you to create your own unique colour combinations.
Inspired by the beloved Romany Surf, the Romany Sport inherits similar characteristics in its design. It’s hull that prioritises stability and a specially shaped foredeck accommodating larger feet up to size 11/12 (Europe 46.5). Complete with knee bumps on both sides of the cockpit, this kayak empowers paddlers to adopt a high wide knee position, optimising ergonomics and enhancing their connection to the water for an exhilarating rough water connectivity.
Features
  • Knee bumps
  • Low rear deck for easy rolling
  • Keyhole cockpit allows quick entry and exit
  • Offset day hatch for access on the water
  • Adjustable seat for amending trim and fit
    • The kayak is fitted with the large High-performance glass seat, unless otherwise requested. It can also be provided with the foam or bucket seat options.
  • Carefully designed weather cocking to ensure you can always turn upwind
  • Skeg to improve handling and wind performance
  • Hull designed to enable smooth edging turns
  • Built in deck fittings to ensure confidence when rescuing and towing
Standard Features
  • Large High-Performance seat
  • Dragon logo decoration on foredeck.
  • Recess for 70P Compass
  • Wire Skeg
  • Adjustable backband
  • Adjustable footrests
  • Round 18cm day hatch
  • Carry toggles bow and stern
Volume (litres)
282.5 160 55 40 27.5
Size (cm)
497 52 32 34.5
Weight (kg)
Standard
27
 Weights are without hatch covers (approx. 1.5kg) and are approximate as all kayaks are built by hand.
