Romany Sportive
For a long time, larger and smaller paddlers were forced to use kayaks ill-fitted to their stature. We pride ourselves in offering a range that provides kayaks designed to perform for every paddler.
The inception of the Pilgrim Expedition stemmed from the remarkable achievements of the Pilgrim model, as paddlers sought a design tailored for extended multi-day excursions with additional gear. Building upon the Pilgrim's triumph, the Pilgrim Expedition has been elongated to enhance volume and cruising speed. The kayak's sleek design ensures swiftness in the water while providing a stable and comfortable platform. This design empowers smaller paddlers to navigate windy conditions effectively, even when carrying substantial gear loads.
During the Kayak to Climb Tasmania expedition, Fiona Corfe utilized a three-piece version of this kayak. This three-month unsupported journey entailed transporting camera and climbing equipment alongside standard expedition gear, showcasing the Pilgrim Expedition's versatility and reliability in demanding real-world conditions.
Lay-up options
Also consider the Pilgrim and Latitude.
Features
  • Knee bumps
  • Low rear deck for easy rolling
  • Sloping bulkhead behind seat to allow easy emptying
  • Keyhole cockpit allows quick entry and exit
  • Offset day hatch for access on the water
  • Adjustable seat for amending trim and fit
    • The kayak is fitted with the small high-performance glass seat, unless otherwise requested. It can also be provided with the medium high-performance or foam seat options.
  • Carefully designed weather cocking to ensure you can always turn upwind.
  • Skeg to improve handling and wind performance
  • Hull designed to enable smooth edging turns
  • Built in deck fittings to ensure confidence when rescuing and towing
Standard Features
  • Small High-Performance seat
  • Recess for 70P Compass
  • Wire Skeg
  • Adjustable backband
  • Adjustable footrests
  • Round 18cm day hatch
  • Carry toggles bow and stern
Volume (litres)
283 130 72.5 42.5 38
Size (cm)
510 50 27 29.5
Weight (kg)
Standard Heavy Duty Elite 50:50 Carbon Kevlar
24 +8-12% -5-7% -10-12.5% -20-25%
 Weights are without hatch covers (approx. 1.5kg) and are approximate as all kayaks are built by hand.
