Explorer HV
A standout choice for expeditions, this kayak stands as the pinnacle of performance for medium to large sized paddlers seeking a blend of speed, agility, and stability. Surpassing the Romany family in speed, the Explorer remains remarkably manoeuvrable and steadfast in direction, offering a thrilling and seamless paddling experience.
Designed with a spacious carrying capacity, the Explorer has proven its mettle on numerous expeditions, including a kit heavy month-long journey in Antarctica, where it bore the weight of all essential supplies without expedition support. This kayak's resilience and reliability have been tested in some of the most unforgiving environments, making it the trusted companion for adventurers seeking to push the boundaries of exploration while maintaining unparalleled performance and confidence on the water.
Same Great Explorer Hull Shape
Tailored for larger paddlers, the Explorer HV retains the exceptional hull of the original model while introducing a redesigned deck to enhance ergonomics for larger paddlers.
By raising parts of the deck in the cockpit and adding strategically positioned raised areas for the knees, this design optimises comfort and legroom without compromising the Explorer's established efficiency, stability, and manoeuvrability.
Lay-up options
Also available in medium and low volume cockpit versions.
Features
  • Knee bumps
  • Low rear deck for easy rolling
  • Sloping bulkhead behind seat to allow easy emptying
  • Keyhole cockpit allows quick entry and exit
  • Offset day hatch for access on the water
  • Adjustable seat for amending trim and fit
    • The kayak is fitted with the large high-performance glass seat, unless otherwise requested. It can also be provided with the medium high performance, foam or bucket seat options.
  • Carefully designed weather cocking to ensure you can always turn upwind
  • Skeg to improve handling and wind performance
  • Hull designed to enable smooth edging turns
  • Built in deck fittings to ensure confidence when rescuing and towing
Standard Features
  • Large high-performance seat
  • Recess for 70P Compass
  • Wire Skeg
  • Adjustable backband
  • Adjustable footrests
  • Round 18cm day hatch
  • Carry toggles bow and stern
Volume (litres)
319 152 73 56 38
Size (cm)
533 54 31.6 34.3
Weight (kg)
Standard Heavy Duty Elite 50:50 Carbon Kevlar
25.4 +8-12% -5-7% -10-12.5% -20-25%
