Greenlander Pro
Evolving from its predecessor, the Greenlander Pro features a keyhole cockpit, a hull extended by 2 inches (50 mm) and a straighter rocker line. It has the classic upturned stern reminiscent of Inuit craftsmanship. We speculate that Inuit kayakers favoured this design, as adjusting the size of the upturned stern could effectively alter the kayak's weather cocking characteristics.
Sponsored Paddler Mirco Goldhausen loves his Greenlander Pro, please see his article, ‘Why choose a Greenlander Pro?’
Lay-up options
Also consider the Greenlander.
Features
  • Traditional Inuit upturned stern
  • Fast chined hull with reduced rocker
  • Low rear deck for easy rolling
  • Sloping bulkhead behind seat to allow easy emptying
  • Keyhole cockpit allowing quick entry and exit
  • Offset day hatch for access on the water
  • Adjustable seat for amending trim and fit
    • The kayak is fitted with a large high-performance seat, unless otherwise requested. It can also be provided with the foam or bucket seat option.
  • Carefully designed weather cocking to ensure you can always turn upwind.
  • Skeg to improve handling and wind performance
  • Chined hull design
  • Built in deck flush deck fittings to ensure confidence when rescuing and towing
Standard Features
  • Large high-performance seat
  • Recess for 70P Compass
  • Wire Skeg
  • Adjustable footrests
  • Round 18cm day hatch
  • Carry toggles bow and stern
Volume (litres)
296 145 66 51 34
Size (cm)
545 53.5 30.5 33
Weight (kg)
Standard Heavy Duty Elite 50:50 Carbon Kevlar
25 +8-12% -5-7% -10-12.5% -20-25%
 Weights are without hatch covers (approx. 1.5kg) and are approximate as all kayaks are built by hand.
