Cadence
This model incorporates several design adjustments, with a prominent feature being the deck shaped to include knee bumps, enabling paddlers to assume a higher knee position for enhanced control in rough water. Additionally, the seat has been repositioned forward to alter trim and increase the kayak's responsiveness in carving turns. To accommodate this seat adjustment, the keyhole cockpit has been lengthened to ensure effortless access and exit.
Same Great Romany Hull Shape
The Romany Plus, which utilizes the proven Romany Classic hull, whilst enhancing rough water capabilities with a deck optimized for challenging paddling conditions. Featuring ergonomic knee bumps for improved control akin to white-water kayaks and a forward seat position for a more forward trim, enabling swift and precise carving turns. The Romany Plus strikes a balance between comfort and high performance for those who prefer the high knee position. These thoughtful modifications elevate the paddling experience without compromising the Romany's celebrated stability and manoeuvrability, making it an exceptional choice for paddlers seeking agility and control in dynamic waters.
The kayak is fitted with the large High-performance glass seat, unless otherwise requested. Can also be provided with the foam or bucket seat options.
Lay-up options
Also available in a low volume and classic versions.
Features
  • Knee bumps
  • Forward seat position for enhanced manoeuvrability
  • Low rear deck for easy rolling
  • Sloping bulkhead behind seat to allow easy emptying
  • Keyhole cockpit allows quick entry and exit
  • Offset day hatch for access on the water
  • Adjustable seat for amending trim and fit
    • The kayak is fitted with the large high-performance glass seat, unless otherwise requested. It can also be provided with the medium high performance, foam or bucket seat options.
  • Carefully designed weather cocking to ensure you can always turn upwind
  • Skeg to improve handling and wind performance
  • Hull designed to enable smooth edging turns
  • Built in deck fittings to ensure confidence when rescuing and towing
Standard Features
  • Large high-performance seat
  • Recess for 70P Compass
  • Wire Skeg
  • Adjustable backband
  • Adjustable footrests
  • Round 18cm day hatch
  • Carry toggles bow and stern
Volume (litres)
319 152 73 56 38
Size (cm)
485 54 30 33
Weight (kg)
Standard Heavy Duty Elite 50:50 Carbon Kevlar
25.4 +8-12% -5-7% -10-12.5% -20-25%
Images:
romany plus green top
romany plus whole
romany plus kevlar
romany plus kevlar close
