For a long time, larger and smaller paddlers were forced to use kayaks ill-fitted to their stature. We pride ourselves in offering a range that provides kayaks designed to perform for every paddler.
Drawing from the beloved design of the Romany Surf, the Romany Excel Expedition has been amplified in all dimensions and lengthened to enhance volume and speed. Ideal for individuals weighing 16+ stones (102+ kilograms) embarking on journeys, this kayak boasts ample volume and waterline length to accommodate all equipment at a comfortable cruising speed.
This kayak incorporates a specially shaped foredeck suitable for larger feet up to size 12/13 UK. Featuring the largest and widest keyhole cockpit in our range, it provides extra legroom thanks to raised areas on each side of the cockpit. The hull shape is distinguished by its boxy hull profile compared to the Romany Classic range, the Romany Excel Expedition ensures stability and connectivity on the waves, optimizing the paddling experience for larger adventurers.
Jeff Atkins of Wave Paddler is an ACA L -5 Coach in the USA and a huge fan of both the Romany Excel and Romany Excel Expedition. Check out his article ‘Kayaks for larger paddlers, Romany Excel, or Excel Expedition? Kayak Dilemma!’
Also available in the Excel and Surf versions.
Features
- Knee bumps
- Low rear deck for easy rolling
- Sloping bulkhead behind seat to allow easy emptying
- Keyhole cockpit allows quick entry and exit
- Offset day hatch for access on the water
- Adjustable seat for amending trim and fit
- The kayak is fitted with the large High-performance glass seat, unless otherwise requested. It can also be provided with the foam or bucket seat options.
- Carefully designed weather cocking to ensure you can always turn upwind
- Skeg to improve handling and wind performance
- Hull designed to enable smooth edging turns
- Built in deck fittings to ensure confidence when rescuing and towing
Standard Features
- Large High-Performance seat
- Recess for 70P Compass
- Wire Skeg
- Adjustable backband
- Adjustable footrests
- Round 18cm day hatch
- Round 24cm Front and Rear Hatches
- Carry toggles bow and stern
Volume (litres) | ||||
Overall | Cockpit | Font Hatch | Rear Hatch | Day Hatch |
424 | 160 | 112 | 68 | 84 |
Size (cm) | |||
Length | Width | Depth (cockpit) | Depth (overall) |
536 | 57 | 32.6 | 35.6 |
Weight (kg) | ||||
Standard | Heavy Duty | Elite | 50:50 | Carbon Kevlar |
28 | +8-12% | -5-7% | -10-12.5% | -20-25% |
Weights are without hatch covers (approx. 1.5kg) and are approximate as all kayaks are built by hand.
Kayak order form | Paddle enquiry form
Contact us | +44 (0) 1407 765550
