Romany Excel
We pride ourselves in having a range to deliver kayaks that will perform for every paddler. The excel has the same great design as the much loved and trusted Romany Surf but it has been expanded in all dimensions. An ideal kayak for the 16+ stones (102+ kilograms) person. The kayak has a larger and wider keyhole cockpit and offers extra leg room due to a raised area either side of the cockpit. Tailored with a hull design that excels in stability, this kayak features a specially shaped foredeck that accommodates larger feet up to size 12/13 UK. Distinguished from the Romany Classic range by its boxy hull profile for enhanced stability, the Romany Excel offers a secure and connected feel on the waves.
The kayak is fitted with the large High-performance seat, unless otherwise requested. Can also be provided with the foam or bucket seat options.
Jeff Atkins of Wave Paddler is an ACA L -5 Coach in the USA and a huge fan of both the Romany Excel and Romany Excel Expedition.  Check out his article ‘Kayaks for larger paddlers, Romany Excel, or Excel Expedition? Kayak Dilemma!’
Lay-up options
Also available in a Expedition and Surf versions.
Features
  • Knee bumps
  • Low rear deck for easy rolling
  • Sloping bulkhead behind seat to allow easy emptying
  • Extra-large keyhole cockpit allows quick entry and exit
  • Offset day hatch for access on the water
  • Adjustable seat for amending trim and fit
    • The kayak is fitted with the large high-performance glass seat, unless otherwise requested. It can also be provided with the foam or bucket seat options.
  • Carefully designed weather cocking to ensure you can always turn upwind
  • Skeg to improve handling and wind performance
  • Hull designed to enable smooth edging turns
  • Built in deck fittings to ensure confidence when rescuing and towing
Standard Features
  • Large high-performance seat
  • Recess for 70P Compass
  • Wire Skeg
  • Adjustable backband
  • Adjustable footrests
  • Round 18cm day hatch
  • Carry toggles bow and stern
Volume (litres)
362 160 90 50 62
Size (cm)
510 57 32.3 35
Weight (kg)
Standard Heavy Duty Elite 50:50 Carbon Kevlar
27 +8-12% -5-7% -10-12.5% -20-25%
